Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimpleRTK kit and a phone (Android/iOS).
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. In this step we want to turn off all broadcast messages except one. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is turned off for UART1. Do NOT change anything for the ports UART2, USB etc. - only turn off all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally, activate message '01-3C NAV-RELPOSNED' for UART1 (this is the only message we want to be broadcast).
6. Choose configuration message 'PRT (Ports)', choose 'UART1', and set baudrate to 115200 for UART1:
Firmware (Arduino Code)
Discussion / forum thread
  1. coming soon
