Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
Firmware (Arduino Code)
Discussion / forum thread
