Ardumower Sunray
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a firmware with more features...
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
