Ardumower Sunray
NOTE: everything here is already working but in early prototype phase! Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
- Optimized for Arduino Due
- SimpleRTK2B - starter kit LR IP67 (it's recommended to purchase the RTK-GPS modules via Marotronics as you get them pre-configured for the Ardumower there)
- Bluetooth BLE UART module (CC2540)
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
