Ardumower Sunray
Warning.png WARNING: everything here is already working but in early prototype phase!
Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
  • Experimental (never run your Ardumower unattended with this firmware)
To be able to use RTK-GPS, your robot mower should have a good view to the sky at all locations (see photo below). RTK-GPS will NOT work directly near walls, under trees, in buildings etc.
PCB     PCB
400px PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
