Ardumower Sunray
'It can mow like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
Requirements (environment and hardware)
PCB     PCB
Significant changes compared to Ardumower's initial firmware (Azurit)
  • Optimized for Arduino Due
400px PCB
PCB     PCB
Firmware (Arduino Code)
Discussion / forum thread
600px
