Ardumower Sunray
Version vom 7. Februar 2020, 14:12 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Firmware (Arduino Code))
'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
PCB     PCB
  • Optimized for Arduino Due
400px PCB
PCB     PCB
Discussion / forum thread
600px
