Chassis (English)
This page describes the assembly of the Ardumower chassis that you can purchase via the shop .
- Wheels: 250mm diameter
- Free wheel: 125mm diameter
- Battery: Lithium-Ion 29.4V
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Assembly: required tools
- Screw driver
- Imbus screw driver
