Perimeter wire
Version vom 26. Oktober 2014, 10:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
While crossing the perimeter loop, something interesting happens: the signal changes its polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire as well as the current state (robot is inside/outside) can be detected. As with perimeter v1, we will again use a motor driver to amplify the signal and an operational amplifier to amplify the received signal. The perimeter sender outputs a code (pseudo-noise), and the receiver will detect that code using a software-based digital matched filter. Depending on wheter the match result peak is positive or negative, the robot is inside or outside of the perimeter wire.
Principle:
Simulation
You can see how it works:
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Software
#define USE_POT for adjust if use an Poti to adjust the Power Out of the Perimter
and
#define USE_CHG_CURRENT if you set it to 1 the Perimter shuts off while the Mower is Charging, if the Charger is not
connected set to 0
Receiver
For receiving the signal, we use a coil in upright position (centered at front in robot), connected to "pinPerimeterLeft". When using the LM386 operational amplifier (to amplify the received signal), capacitor C3 should be bypassed (will give a VCC/2 offset required for Arduino) and the coil will be connected to "IN" and "GND".
receiver circuit:
Flux directions
ADC calibration
Note: Run the ADC calibration once ("pfodApp->ADC Calibration"), so that the received signal is symmetric around zero. The Perimeter Transmiter must be off while Calibration.
Diagnostics
Sender status LED (Arduino LED):
sig:  coil signal
mag:  filter result: inside (negative) or outside (positive), strengh: distance to perimeter wire - this is used for perimeter tracking
on:   perimeter sender active (1) or inactive (0)
  1. Perimeter2 demo
  2. 120m perimeter wire test
