Level 2 Raspberry Pi
What you need
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
First PC connection over Wifi
PI SIDE
PC SIDE or Tablet / Phone
You have many possiblity (SSH viewer, MobaXterm, Remote Desktop etc...) , In this case I use free real VNC Viewer to connect to the PI over your network.
