- 1 Level 2 Raspberry Pi
- 1.1 Setup
- 1.2 Piardu Description
Setup
What you need
Fast setup for Advanced user
Here the full setup process:
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
Pygame
Paho Mqtt
KST Plot
DosToUnix
Arduino IDE
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
cd PiArdumower
cd Documents/PiArdumower
dos2unix Restart.py
cd ~/Desktop
dos2unix mower.sh
DUE Connection
On setting main tab use Update the DUE Firmware button and click on Start Flash
Again click Back icon and Setting icon and click on Reboot All
The Raspberry and DUE reboot
if you use the PCB1.3 maybe you need to activate raspberryPi use to YES into arduremote / Setting / Raspberry.
Automatic start on Power up:
Optional Screen
cd LCD-show/
sudo ./LCD5-show
Optional Camera
Check to Enable the Camera
Move windows or Hit Tabulation 10 times because you can't see Validate Button and press Enter (Reboot)
Piardu Description
It's here : [[1]]
