AzuritBer Pi Firmware RFID(English)
Version vom 23. November 2020, 19:05 Uhr von Bernard (Diskussion | Beiträge) (→‎Level 3 Raspberry Pi + RFID Reader)
It use SPI interface to communicate with ESP32 and ESP32 replace the bluetooth module HC05 to communicate with PCB1.3, so you can build a small PCB to connect all wire, or order some of them from JLCPCB for example (The same board is also use to build the WIFI sender.)
Here the first version with wrap on smal PCB:
and the PCB use to connect everything (Rfid reader / PCB1.3 / Wifi sender)
