AzuritBer Pi Firmware RFID(English)
Version vom 2. Dezember 2020, 14:42 Uhr von Bernard (Diskussion | Beiträge) (→‎Hardware connecting)
Hardware connecting
It use SPI interface to communicate with ESP32 and ESP32 DEV KIT replace the bluetooth module HC05 to communicate with PCB1.3, so you can build a small PCB to connect all wire, or order some of them from JLCPCB for example (The same board is also use to build the WIFI sender.)
Using arduino IDE , You can download firmware inside ESP32 to have everything working : https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID
Setting
