Chassis (English)
Version vom 15. Oktober 2020, 20:55 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Ardumower 1.0 Chassis specifications)
  • Total weight: approx 9 kg (including all components - motors, battery, PCB etc.)
  • Adjustable mower motor height
  • Mowing motor: 24V DC, 3150 rpm, 140 mNm, 46W
  • Mowing disc: 190mm diameter, 3 blades
  • Wheels: 250mm diameter
  • Free wheel: 125mm diameter
  • Gear motors: 2 x DC 24V planetary drive, 31 rpm, 2.45 Nm, 8mm shaft, with integrated encoders
  • A high torque (2.45Nm) guarantees that the robot can climb small hills as well (with 2 motors, 0.125 radius wheel, 31rpm = 0.4m/s = 1.5 km/h, acceleration = 0.2 ( 1/2 of nominal speed) see calculator
  • Battery: Lithium-Ion 29.4V (125Wh or 250Wh)
  • Total energy consumption (average): 40W (60W peak, 7W idle)
  • Max. incline: approx. 30%
  • Material: PE-HD plates (8mm) and alumnium profiles
  1. Ardumower at Berlin Maker Faire 2019 (Source: "hallo deutschland")
  2. Building an Ardumower: chassis, motors, tires assembling
  3. Building an Ardumower: chassis, motors, tires assembling (slow)
  4. Overall impression
  5. Loundness test
  6. Gear motor test
  7. Gear motor hardness test
  8. Mowing motor hardness test
  9. Perimeter wire test (indoor)
  10. Perimeter wire test (120m outdoor)
  11. Obstacle detection via motor current
  12. Obstacles detection via ultrasonic
  13. Robot releases itself
  14. Robot releasing long-time test
  15. Plastic blades test
  16. Docking test (very initial prototype)
  17. Rain sensor test
  18. 3D simulation
Required Tools
  • Screw driver
  • Different Torx screw driver
  • Knife
Optional Tools
  • Round and flat file
  • Electric padsaw
Optional Material
  • M4 washer and spring washer
  • 1 M8 carriage bolt
  • Rain sensor case 3D print from model
  • Case for NTRIP receiver module for GSPS variant of the Ardumower
Case assembly
Gear motors
Tires
Mower motor
Mowing disc
Free wheel
Anleitung für das Ardumower Komplettset
Mähmotor und Mähscheibe
CAD files
Ardumower blades etc.
