Brushless Drive
Version vom 10. April 2021, 17:57 Uhr von BerndS (Diskussion | Beiträge) (→‎Brushless Driver specifications:)
ArduMower Brushless Drive
....under construction!!
Why brushless and what are the advantages?
The disadvantage is, a brushless motor and his driver are much more expensive than a brushed DC motor. But if you see the total cost over ArduMower live time, you will see an overall cost reduction abd a very fast return on investment, especially for large lawn area. The cost advantage will take place after 2-4 years (depends on lown area and mower usage), by end of life of the brushes and commutator of an DC Motor, where you have to replace the DC Motor by a new one. So for high usage on large areas, you will amortize the higher invest within 2 or 3 years and save a lot of money.
DC motor drive : small lown area, less working hours of the ArduMower per week.
Brushless drive: large lown areas and 5-7 days / week usage of the ArduMower. Longer working period per battery charging cycle.
ArduMower drive concept
Since 2021, the ArduMower project supports a wide scale of drive options. From the powerful and cost efficient DC motor over the special AduMover Brushless Drive for larger power drive up to high power drive with commercial brushless controllers. The DC and the AduMover Brushless Drive are supported by the community and the parts will be availably in the online shop [1]. The high power drive is very special and needs some individual adaptions. If you are interested please get in contact with BerndS via ArduMower Forum.
ArduMower Brushless Drive Concept
  • *for more than 32V power, you have to change the voltage protection diode.
ArduMower Brushless Drive :
ArduMower Brushless Drive Unit
- Operating Supply Voltage 8.5V to 32 V
- Operating junction temperature range (Contr. & MOSFETs)  -40°C – 150°C
- max. motor current 3,5A (continues current)
   MOSFET continues current min. 5A / peak current min.30A (we use 3,5A Fuse)
   MOSFET max. Voltage 60V ( board is limited to 32V by a TVS protection diode)
- Integrated Overcurrent, Overvoltage and Overtemperature Protection
- HAL Sensor loop back, to stabilize the motor speed automatically by the DRV
- Individual programmable motor parameter for different motor designs
- Motor speed control by PWM, impulse or SPI interface (software, register controlled)
The main advantage of this controller is the flexibility, to optimize the controller parameter individually for different motor types &HAL sensors and optimize the parameter for each motor type. But the advantage is on the other hand also the disadvantage. Without programming, the Brushless Driver board it is not working. Before you can use the device, you have to write your motor parameter in the OTP (one-time programmable) non-volatile memory. Once programmed, the DRV uses this parameter by default, during power up.
IMORTANT : The OTP can programmed only ONE time! OTP changes afterwards are not possible.
Brushless Drive Architecture
ArduMower Brushless Drive block diagram
