DIY Brushless Driver Board
Version vom 26. August 2021, 19:53 Uhr von BerndS (Diskussion | Beiträge) (→‎DIY ArduMower Brushless Driver Kit)
PCB1.x with Brushless Driver(Pic. by Uwe)
 Brushless Drive [2]
 Brushless Adapter [3]
 Blade-Motor Protection  [4]
Description
Brushless Drive Test Software
  1. define Reg00
  1. define Reg0B
Connector Pinout
HAL Sensor:
clamp + : 5V Power out for HAL sensoric (ACT Motor HAL cable : red )
clamp - : GND for for HAL sensoric (ACT Motor HAL cable : black )
clamp U : HAL sensor U (ACT Motor HAL thin cable : yellow )
clamp V : HAL sensor V (ACT Motor HAL thin cable : green )
clamp W : HAL sensor W (ACT Motor HAL thin cable : blue )
Motor Coils:
clamp U : coil U (ACT Motor HAL thick cable : yellow )
clamp V : coil V (ACT Motor HAL thick cable : green )
clamp W : coil W (ACT Motor HAL thick cable : blue )
Step 1 Soldering :
Step 2 Connect the Brushless Motor :
Step 3 Connect the Power :
3D-printed PCB holder
Bug fix
220nF at each odometry input
Fuse on PCB1.4, wire going up, over the fuse before they turn down
Stock all contacts at the power side and do NOT add coolers to 7805 power IC
