Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 16:58 Uhr von Alexanderg (Diskussion | Beiträge)
[File:Ardumower_reverse_bumperduino.jpg|400px]
- optional: modifying the tire profile (give it more grip)
- Modify tire profile OR
- Off-road version (sand etc.): A bicycle tube or U-form rubber is added around the tire
Needed parts
- cup
- acrylic glas sheet (1mm)
- rubber band (U-form)
- swap motor cables (right and left)
- swap odometry cables (right and left)
- swap battery charging pin cables (right and left)
- disable ultrasonic sensor
- move perimeter coil from old front to old back side
- use BumperDuino as bumper sensor
New rubber tires
pushcart tires adapter
Pictures
- BumperDuino
- pushcart tires
- Demo
- Optimized tires
