Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 19:12 Uhr von Alexanderg (Diskussion | Beiträge) (→New rubber tires (optional))
- optional: modifying the tire profile (give it more grip)
- Modify tire profile OR
- Off-road version (sand etc.): A bicycle tube or U-form rubber is added around the tire
Needed parts
- cup
- acrylic glas sheet (1mm)
- rubber band (U-form)
- swap motor cables (right and left)
- swap odometry cables (right and left)
- swap battery charging pin cables (right and left)
- disable ultrasonic sensor
- move perimeter coil from old front to old back side
- use BumperDuino as bumper sensor
For even higher traction, one can use [File:https://www.marotronics.de/Air-wheel-260-mm-eg-for-Ardumower-handcart-wheel-hand-cart-wheel-wheelbarrow-wheel
pushcart tires from the shop]. Using a 3d printed adapter one can mount them onto the Ardumower clamping element.
pushcart tires adapter
Pictures
- BumperDuino
- pushcart tires
- Demo
- Optimized tires
