Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 19:13 Uhr von Alexanderg (Diskussion | Beiträge) (→‎New rubber tires (optional))
  2. optional: modifying the tire profile (give it more grip)
    1. Modify tire profile OR
Needed parts
  • cup
  • acrylic glas sheet (1mm)
  • rubber band (U-form)
  1. swap motor cables (right and left)
  2. swap odometry cables (right and left)
  3. swap battery charging pin cables (right and left)
  4. disable ultrasonic sensor
  5. move perimeter coil from old front to old back side
  6. use BumperDuino as bumper sensor
For even higher traction, one can use pushcart tires from the shop. Using a 3d printed adapter one can mount them onto the Ardumower clamping element.
pushcart tires adapter
Pictures
  1. Ardumower rear/front driven climbing difference
  2. BumperDuino
  3. pushcart tires
  4. Demo
  5. Optimized tires
  6. Bicycle tube tires for 'off-road'
Other ideas
Forum
