Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 20:29 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Turning front drive into rear drive)
  2. optional: modifying the tire profile (give it more grip)
    1. Modify tire profile OR
Needed parts
  • cup
  • acrylic glas sheet (1mm)
  • rubber band (U-form)
  1. on PCB, swap right motor cables with left motor cables (so left motor is right motor and vice versa)
  2. on PCB, swap polarity of each motor (so turning forward is turning backward)
  3. on PCB, swap odometry cables (so left odometry is right odometry and vice versa)
  4. mount battery charging pin at chassis handle side
  5. disable ultrasonic sensor
  6. move perimeter coil from old front to old back side (if using perimeter sensor)
  7. use BumperDuino as bumper sensor
New rubber tires (optional)
For even higher traction, one can use pushcart tires from the shop. Using a 3d printed adapter one can mount them onto the Ardumower clamping element.
pushcart tires adapter
Pictures
  1. Ardumower rear/front driven climbing difference
  2. Ardumower rear-driven, BumperDuino demo
  3. pushcart tires
  4. Demo
  5. Optimized tires
  6. Bicycle tube tires for 'off-road'
Other ideas
Forum
