Ardumower Chassis 'mountain mod'
Version vom 13. September 2021, 20:29 Uhr von Alexanderg (Diskussion | Beiträge) (→Turning front drive into rear drive)
- optional: modifying the tire profile (give it more grip)
- Modify tire profile OR
- Off-road version (sand etc.): A bicycle tube or U-form rubber is added around the tire
Needed parts
- cup
- acrylic glas sheet (1mm)
- rubber band (U-form)
- on PCB, swap right motor cables with left motor cables (so left motor is right motor and vice versa)
- on PCB, swap polarity of each motor by swapping +/- (so turning forward is turning backward)
- on PCB, swap odometry cables (so left odometry is right odometry and vice versa)
- mount battery charging pin at chassis handle side
- disable ultrasonic sensor
- move perimeter coil from old front to old back side (if using perimeter sensor)
- use BumperDuino as bumper sensor
New rubber tires (optional)
For even higher traction, one can use pushcart tires from the shop. Using a 3d printed adapter one can mount them onto the Ardumower clamping element.
pushcart tires adapter
Pictures
- Ardumower rear-driven, BumperDuino demo
- pushcart tires
- Demo
- Optimized tires
