Version vom 18. Mai 2023, 11:09 Uhr von Bernard (Diskussion | Beiträge) (→‎Raspberry Pi)
Raspberry Pi
A Raspberry Pi is connected over : Due Native USB to arduino DUE or on USB port to AGCM4/Teensy
Setup
What you need
Fast setup for Advanced user
Here the full setup process:
sudo apt-get install idle3
sudo pip3 install paho-mqtt
sudo apt-get install kst
sudo apt-get install dos2unix
cd ~/Documents
sudo chmod -R 755 PiArdumower
cd PiArdumower
mv mower.sh /home/pi/Desktop
cd ~/Documents/PiArdumower
dos2unix streamVideo320.py
dos2unix streamVideo640.py
dos2unix DueFlash.py
dos2unix PowerOff.py
dos2unix Restart.py
dos2unix testnet1.py
cd ~/Desktop
dos2unix mower.sh
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
Pygame
Paho Mqtt
What you can send to mower
Topic Denna/COMMAND
payload : STOP to stop
payload : MOWPATTERN ;1 or 2 or3 according mowpattern
payload : START to start with the last mowpattern
payload : PAUSE;2 to stop auto start by timer for the next 2 hours
payload : HOME to go station
payload : STARTTIMER;1;1;0;25;2;50 it's to start from station
What you receive from mower
Send only when value change
Topic Denna/STATUS
Topic Denna/STATE
Topic Denna/Battery
payload the bat voltage
Topic Denna/Temp
payload the mower temp
Topic Denna/Battery
Topic Denna/Idle
KST Plot
DosToUnix
Arduino IDE
Warning : folder arduino-1.8-13 can change over time for example arduino-1.8-15 , so use the correct name according your download in the next command.
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
cd PiArdumower
cd Documents/PiArdumower
dos2unix Restart.py
cd ~/Desktop
dos2unix mower.sh
Automatic start on Power up:
If you can't see the bottom red line with date time : check if you have activate raspberryPi to YES using Arduremote / Setting /raspberry
DUE Connection
If you can't remove Arduino DUE from PCB1.3 : you need to power the raspberry with the DC/DC voltage regulator under the same battery, or with standard PI power supply.
FLASH DUE
CHECK COMMUNICATION
change with:
Optional Screen
Be carreful when you order : HDMI adaptor is not the same for PI4 (Right Picture) and PI3B+ (center and left Picture)
To setup the tactile and screen :
Go to terminal :copy and paste these command
cd LCD-show/
sudo ./LCD5-show
Optional Camera
Check to Enable the Camera
Expérimental AI Vision with Tensorflow
Fast main setup description.
core
data
protos
utils
vision
Now in a new terminal :
sudo apt-get update
Install OPENCV
Install Tensorflow
pip3 install tensorflow
For example on COCO model the chair have ID 62 and we want to stop and reverse if detection score is > 75 and area > 12 % of the screen.
AGAIN IT'S EXPERIMENTAL AND ONLY FOR FUN so check in the python shell that no error occur and test to see if the detection is reliable !!
Backup SD CARD
Download the soft and start it.Your SDCARD is normaly detected and you only need to select a backup folder and give a name to the file ,add .img at the end of your backup file
TO BACKUP
TO RESTORE
Piardu Main Configuration
Inside folder : home/pi/Documents/Piardumower you can edit the config.py file to manage different option :
PCB part:
GPS part:
Warning : GPS is not use by software,it's only a tracker version, All data are recorded and saved inside Piardumower/Gpsdata
Arduino Nano part.
NanoConnectedOnPi
Battery part:
AutoRecordBatCharging
Debug part:
UseDebugConsole
Sender part:
Camera part:
myCamAngle
streamVideoOnPower
Piardu Power ON / OFF video
Result after everything correctly set :
Power ON
https://youtu.be/Qhv8r2bD_Bk
Power OFF
https://youtu.be/4YJQ-zyLq-Q
Piardu MENU Description
Full description is here:
https://wiki.ardumower.de/index.php?title=AzuritBer_Pi_Explain_(English)
