Motor driver
Version vom 15. Januar 2015, 12:45 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Mower motor (MOSFET))
Ardumower uses two different motors:
  • Two motors (with integrated gearing) for driving (wheel motors)
Voltages
There exist 12V motors and 24V motors. As in all modern systems, the Ardumower uses 24V motors. The reason is as follows:
  • The motor driver must be suitable for higher current (more expensive)
  • The PCB traces need to be more thick (more expensive)
  • The rechargable battery need to support higher current (more expensive)
Wheel motors
The two left and right gear motors are controlled independantly to:
  • drive forward/backward
  • steer left/right
The motor features:
  • Integrated encoders, so it can measure the rotation speed. This allows Ardumower to correct the driving angle
  • A high torque (3Nm) guarantees that the robot can climb small hills as well
  • A rotation speed up to 33 rpm allows to move at moderate speed
Motor driver
 Arduino Digital Pin  —>  MOTOR-Direction Pin (DIR)
 Arduino PWM Pin      —>  MOTOR-Speed Pin (PWM)
 Arduino Analog Pin   <—  MOTOR-Current Sensor Pin
Popular modules
MC33926
For the 0.9.3 Version
M1_FB     --- Motor1 current sensor output (Arduino)
M1_IN1    --- Motor1 PWM (Arduino)
M1_IN2    --- Motor1 Dir (Arduino)
EN        --- connect with jumper to VDD
M2_FB     --- Motor2 current sensor output (Arduino)
M2_IN1    --- Motor2 PWM (Arduino)
M2_IN2    --- Motor2 Dir (Arduino)
VDD       --- Arduino 5V
For the SVN Version
M1_FB     --- pinMotorLeftSense A1
M1_SF     --- pinMotorLeftFault 25
M1_IN1    --- pinMotorLeftPWM 5
M1_IN2    --- pinMotorLeftDir 31
M2_FB     --- pinMotorRightSense A0
M2_SF     --- pinMotorRightFault 27
M2_IN1    --- pinMotorRightPWM  3
M2_IN2    --- pinMotorRightDir 33
VDD       --- Arduino 5V
L298N
Connect in parallel:
IN1 with IN4
IN2 with IN3
OUT1 with OUT4
OUT2 with OUT3
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.).
L9958 GND---GND
L9958 VCC---Arduino 5V
L9958 EN---Arduino 5V
L9958 DI---GND
L9958 DIR---Arduino MOTOR_DIR
L9958 PWM---Arduino MOTOR_PWM
L9958 MOTOR(+)---motor(+)
L9958 MOTOR(-)---motor(-)
L9958 POWER(+)---battery(+)
L9958 POWER(-)---battery(-)
Mower motor
The mower motor features:
  • Enough torque (140 Nm)
Choosing a driver
  • price
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
