Sensor errors
Odometry sensor
  • Distance: 20cm per meter
  • Course: 10 degree per meter
  1. Calculation of short-time position by Odometry and Compass
  2. Calculation of long-term position via GPS
A Kalman filter can be used to fuse all sensor values.
Mapping and localization (SLAM)
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
Lane-by-lane mowing
