Sensor errors
Odometry sensor error
- Distance: 20cm per meter
- Course: 10 degree per meter
- Calculation of short-time position by Odometry and Compass
- Calculation of long-term position via GPS
A Kalman filter can be used to fuse all sensor values.
Position recalibration
Mapping and localization (SLAM)
Input to SLAM algorithm:
Output from SLAM algorithm:
Example SLAM algorithms:
Lane-by-lane mowing
Simulation
