Everything under development here. Just showing ideas! :-)
- speed (m/s)
- direction (degree)
- position (x,y - meter)
Sensor errors
Odometry sensor error
- Distance: 20cm per meter
- Course: 10 degree per meter
A Kalman (or EKF) filter can be used for sensor fusion.
Example (simplified):
- Calculation of short-time position by Odometry and Compass
- Calculation of long-term position via GPS
Position recalibration
Mapping and localization (SLAM)
Input to SLAM algorithm:
Output from SLAM algorithm:
Example SLAM algorithms:
Lane-by-lane mowing
Simulation
