- speed (m/s)
- direction (degree)
- position (x,y - meter)
Sensor errors
Odometry sensor error
- Distance: 20cm per meter
- Course: 10 degree per meter
A Kalman or Extended Kalman Filter (EKF) filter can be used for sensor fusion.
Note: This estimated position will need to be corrected by an absolute position estimation, e.g. perimeter field strength (and a particle filter).
Position recalibration
Mapping and localization (SLAM)
Input to SLAM algorithm:
Output from SLAM algorithm:
Example SLAM algorithms:
Lane-by-lane mowing
Simulation
