NOTE: Everything under development here. Just showing ideas! :-)
  • speed (m/s)
  • direction (degree)
  • position (x,y - meter)
Sensor errors
  • Odometry: accumulation error (e.g. 15cm per meter), update rate: 10-20 Hz
  • Gyro: accumulation error (e.g. 1 degree per second), update rate: 10-20 Hz
  • Compass: noise (e.g. 1 degree), update rate: 10-20 Hz
  • GPS: noise (e.g. 2m), update rate: 1-5 Hz
Odometry sensor error
  • Distance: 20cm per meter
  • Course: 10 degree per meter
A Kalman or Extended Kalman Filter (EKF) filter can be used for sensor fusion.
Gyro         => Rotation speed delPhi   =>
Course(GPS)  => Course phiGPS           => Kalman =>  Course phi       =>
Odometry     =>                                       Distance Sl, Sr  =>  Kalman  =>  Position x,y, Course phi
Note: This estimated position will need to be corrected by an absolute position estimation, e.g. perimeter field strength (and a particle filter).
Position recalibration
  1. Learn mode: robot completely tracks perimeter wire once and saves course (degree) and distance (odometry ticks) in a list (perimeter tracking map).
  2. Position detection: robot starts tracking the perimeter wire at arbitrary position until a high correlation with a subtrack of the perimeter tracking map is found. There it can stop tracking and knows its position on its perimeter tracking map.
Mapping and localization (SLAM)
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
SLAM simulation
  1. The simulator code can be found in SVN
  2. The simulator IDE+compiler+precompiled libs (CodeBlocks) can be downloaded here - Extract the .zip to 'C:\codeblocks' and run 'sim.cbp'
Videos: Magnetic field localization using particle filter
Lane-by-lane mowing
Simulation
