IMU
Version vom 10. Februar 2015, 10:55 Uhr von Grint (Diskussion | Beiträge) (Grammar / spelling changes)
Additionally, gyro/acceleration and compass sensors can be further input to a position estimation.
IMU module GY-80
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
Calibration abstract
Example measurements
Calibration (v0.9.3)
This one-time calibration ensures that all 3 axes measurements are weighted equally. This calibration can even be performed externally to the robot.
2.1. After calibration, each of the 6 sides of the module has to look up-side and down-side (rotated 180 °). The module has 6 sides, so it must be rotated 6 times, so that each side once is on the table (you can hold the module with your hand without moving it). Press ENTER after each calibration step. The aim of the calibration to determine the acceleration due to gravity (more precisely, the minimum / maximum value) for each axis . The module must not be artificially accelerated. The order of the sides does not matter.
1. Download ArduMag calibration app for Android. 2. If not done yet, pair your Android device with the Bluetooth module: On the Android device main screen, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired". 3. In the ArduMag app, press the Android menu key and then "Bluetooth" to connect with your Bluetooth module (and your robot). The robot should confirm the connection with a beep. The number of measurements should increase.
The order of the axis of rotation and the direction does not matter. For example, rotate each side 180 degree clockwise and then again 180 degree counterclockwise (result is a 360 degree rotation). The measurements may not fit a sphere. Examples:
Finally, press 'Calibrate' to finish the calibration. The robot will confirm the calibration with two beeps. The measurements should fit a sphere now. Examples:
Compass deviation
Calibration test
Testing of compass and tilt angles (via serial console)
The Arduino outputs:
Testing (by using LED)
Testing (via Android pfodApp)
Calibration (SVN version)
Calibration quality test
Table test
calls=30    yaw=-95.56    pitch=0.02    roll=2.52    com=-95.91    com180=84.09    gyroZ=0.00
calls=30    yaw=-95.48    pitch=-0.11    roll=2.33    com=-95.81    com180=84.19    gyroZ=-0.01
calls=30    yaw=-95.42    pitch=0.03    roll=2.42    com=-95.65    com180=84.35    gyroZ=-0.00
calls=30    yaw=-95.45    pitch=-0.21    roll=2.38    com=-95.35    com180=84.65    gyroZ=-0.00
calls=30    yaw=85.06    pitch=-2.50    roll=0.04    com=84.91    com180=-95.09    gyroZ=-0.03
calls=30    yaw=84.90    pitch=-2.59    roll=0.05    com=84.63    com180=-95.37    gyroZ=-0.02
calls=30    yaw=85.19    pitch=-2.55    roll=0.01    com=84.73    com180=-95.27    gyroZ=-0.01
calls=30    yaw=84.98    pitch=-2.73    roll=0.02    com=84.85    com180=-95.15    gyroZ=-0.01
pfodApp test
  1. Robot dance
  2. Keep on track
  3. Driving lanes
