Ardumower chassis
Version vom 12. Februar 2015, 11:39 Uhr von Alexanderg (Diskussion | Beiträge)
- Weight: approx 10 kg with motors and battery
- Mowing slice: 190mm diameter, 3 blades
- Wheels: 250mm diameter
- Gear motors: 2 x DC 24V planetary drive, 33 rpm
- Battery: Lithium-Ion 24V
- Max. slope: 20 degree
- Chassis assembling
- Chassis assemling (slow)
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
What you need
- Screw driver
- Imbus screw driver
Case assembly
... Your help is needed to fill in photos here ...
