- speed (m/s)
- direction (degree)
- position (x,y - meter)
Sensor errors
- Gyro: accumulation error (e.g. 0.03 degree per second), update rate: 10-20 Hz
Odometry sensor error
- Distance: 20cm per meter
- Course: 10 degree per meter
Sensor fusion (EKF)
Sensor fusion (Gyrodometry)
The idea of 'Gyrodometry' is to compare delta phi of gyro and odometry. If it is higher than a certain threshold, use gyro delta phi, otherwise odometry delta phi.
if (deltaPhiGyro - deltaPhiOdo) > deltaThres phi = phi + deltaPhiGyro * T else phi = phi + deltaPhiOdo * T
Position recalibration at perimeter border
Mapping and localization (SLAM)
Input to SLAM algorithm:
Output from SLAM algorithm:
Example SLAM algorithms:
SLAM simulation
Videos:
Lane-by-lane mowing
Assuming a lane length of 10m, and a lane width error of +/- 0.1m, the maximum allowed yaw error is:
yaw error=arcsin(0.1m/10m) = 0.5 degree
Assuming that robot moves at 0.4m/sec, the actual yaw error can be computed like this:
actual time needed = 10 meters / 0.4m/sec = 25 seconds
Actual yaw error (assuming gyro noise 0.005 degree/sec):
actual yaw error = 0.005 degree/sec * 25 seconds = 0.125 degree
Sensor logging
- Using your Android pfodApp, connect to your robot and choose 'Log sensors'. The logged sensor data will be displayed. Click 'Back' to stop logging.
- On your PC, launch Windows Explorer and choose the new Android drive, browse to the 'pfodAppRawData' folder, and copy the data file to your PC (you can identify files by their Bluetooth name and date).
Simulation
