Charging
Version vom 7. April 2015, 16:13 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Undervoltage protection)
Basic principle
Charger
Battery
For the battery, we are using a 'Sony Konion 7S2P' Lithium Ion battery pack (Sony Konion US18650V3 2250 mAh cells, Li-Mn), 29.4V, 4500 mAh, 500 recharge cycles, 126 x 36 x 65 mm (LBH).
The robot should be able to switch off the battery itself (undervoltage protection).
Idea:
  • Emergency push button: can power-off the robot immediately
  • POWER/START button: switches on operation voltage (1st press), starts robot in automatic mode (2nd press)
  • Arduino power signal pin (OUT): set to HIGH at bootup - set to LOW if undervoltage detected
battery (+) ---- emergency push button (emergency OFF) ----- relay switch ------ operation voltage (+)
                                                               control
POWER/START button -----diode-------------------------------------|
Arduino power signal pin (OUT) -----diode-------------------------|
battery (-)
Robot
In the robot itself, the battery voltage is monitored (see diagram below). So it can be determined when the robot must go to the charging station. The robot and the voltage and the current during charging is controlled. So it can be determined whether the robot has reached the charger and when the battery is fully charged again. Ideally, the charging station also powers the loop transmitter:
charging station circuit:
                 GND         (-)----- Charging station charger pin(-)
                 Charger 24V (+)----- DC-DC converter 5V  => Perimeter sender Arduino Nano
robot charging circuit:
                               ---- voltage sensing
Charging station ideas
  2. Drive in and out
  3. Tracking and docking
