Charging
Basic principle
Charger
Battery
For the battery, we are using a 'Sony Konion 7S2P' Lithium Ion battery pack (Sony Konion US18650V3 2250 mAh cells, Li-Mn), 29.4V, 4500 mAh, 500 recharge cycles, 126 x 36 x 65 mm (LBH).
Undervoltage protection
Modern batteries should not be completely discharged. When the robot isn't able to charge for some reason and when the battery is below a certain threshold, it should be able to switch off the battery itself (undervoltage protection)
Idea:
User presses existing START/POWER button, that switches on the relay for the time of pressing - Arduino starts and immediately also switches on relay - if undervoltage detected, Arduino switches off relay. Emergy button is still used for completely switching ON/OFF power.
- Emergency push button: can power-off the robot immediately
- POWER/START button: switches-on operation voltage (1st one second press), starts robot in automatic mode (2nd one second press)
- Arduino digital out pin (power signal): set to HIGH at bootup - set to LOW if undervoltage detected
battery (+) --- emergency push button (emergency OFF) --+------- battery relay switch ------ robot battery operation voltage (+)
|-----+- battery relay coil -----
battery (-) --- GND | |
Arduino digital out pin | |
(pinBatteryEnable) -----------------------2K-----------------transistor BC547 |
GND |
POWER/START button -------+--diode--<---------------------------------------------------|
GND diode
Arduino digital in pin --|
(pinButton) pull-up
Robot charging
robot charging circuit:
---- voltage sensing
Charging station
charging station circuit:
Charger 24V (+)----- DC-DC converter 5V => Perimeter sender Arduino Nano
Charging station ideas
