Version vom 29. April 2015, 12:48 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How to report a new bug/new feature/new code)
Disabled all pins not connected?
Motors working correctly?
Any unexpected sensor triggering?
Some sensor not triggering?
Bluetooth not connecting?
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
