GPS
Version vom 22. Mai 2015, 19:59 Uhr von Alexanderg (Diskussion | Beiträge) (→Visualization of GPS data)
Currently, GPS is used
GPS TX (3.3V compatible) -- Arduino RX GPS RX (3.3V compatible) -- Arduino TX GPS VCC -- Arduino VCC 5V GPS GND -- Arduino GND
hdop measurement error (the more satellites are from different directions, the lower the error) sat number of satellites in view spd ground speed course ground course alt altitude lat latitude lon longitude
GPS error
Typical GPS error is 2-5 meters (at a sample rate of 1 Hz). As this is not sufficient as a replacement for a perimeter wire, GPS can only be seen as an extension or for global navigation (navigation from one lawn to another lawn) or to improve the result of a sensor fusion.
