GPS
Version vom 22. Mai 2015, 20:04 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Visualization of GPS data)
Currently, GPS is used
GPS TX (3.3V compatible) -- Arduino RX
GPS RX (3.3V compatible) -- Arduino TX
GPS VCC -- Arduino VCC 5V
GPS GND -- Arduino GND
spd     ground speed m/s
course  ground course degree
alt     altitude meter
lat     latitude
lon     longitude
GPS error
Typical GPS error is 2-5 meters (at a sample rate of 1 Hz). As this is not sufficient as a replacement for a perimeter wire, GPS can only be seen as an extension or for global navigation (navigation from one lawn to another lawn) or to improve the result of a sensor fusion.
