Arduino code techniques
Version vom 11. September 2014, 14:46 Uhr von Alexanderg (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „This page shows common code techniques that can be useful on the Arduino. =Mean filter= Problem: you have multiple ADC measurements (battery, ultrasonic etc.)…“)
Mean filter
Problem: you have multiple ADC measurements (battery, ultrasonic etc.) that can contain outlier. What value is the most seen value? Solution: This code will sort and choose the center value. Example: 1,5,6,7,32 => returns center value (6)
unsigned int ADCmedian(int pin, int count) {
int values[count], last;
uint8_t j, i = 0;
values[0] = 0;
while (i < count) {
last = analogRead(pin);
if (i > 0) {
for (j = i; j > 0 && values[j - 1] < last; j--) // Insertion sort loop.
values[j] = values[j - 1]; // Shift ping array to correct position for sort insertion.
} else j = 0; // First ping is starting point for sort.
values[j] = last; // Add last ping to array in sorted position.
i++; // Move to next ping.
if (i < count) delay(1);
return (values[count/2]); // Return the median.
