Echtzeit-Uhr
Version vom 14. Juli 2015, 12:07 Uhr von Amadeus (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „ == '''Realtime clock (RTC)''' == The robot requires a clock, so that it can start mowing automatically at certain time intervals (timer). A realtime clock…“)
A realtime clock (RTC) returns current time (minute, hour) and date (day of week, day, month, year) - by the help of a battery the time continues to run even if the robot mower is switched off.
Additionally, the RTC module contains an EEPROM memory (non volatile memory) that can hold 4K of permanent user data.
Example: DS1307
Wiring
The RTC module is connected on the I2C bus of the Arduino Mega (in parallel with any other I2C modules).
 DS1307 Module SDA       — Arduino SDA Pin
 DS1307 Module SCL       — Arduino SCL Pin
 DS1307 Module VCC (+5V) — Arduino VCC (+5V)
 DS1307 Module GND       — Arduino GND
Note
If you experience communication problems when using multiple I2C modules on one I2C bus, it is recommended to reduce the length of the cables.
Timer
Timer 3: off
Timer 4: off
