Version vom 17. Juli 2015, 13:15 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Disabled all pins not connected)
Error codes
If your robot beeps periodically, it is in ERROR state. Either run the serial console or 'pfodApp->Error Counters' to find out the detailed error. The possible solutions for each error are given below.
 ERR_MOTOR_LEFT          Left gear motor error
                         * Check gear motor driver module and left gear motor
                         * Check gear motor driver module and right gear motor
                         * Check mower motor driver module and mower motor
                         * Check RTC module connections, battery etc.
                         * Check left odometry cable
                         * Check right odometry cable
                         * Check battery connections
                         * Check charger connections
                         * Check GPS cables
                         * Check GPS antenna and cable
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
 START
 Ardumower rXXXX
 press...
   d for menu
- After-home-drive? (1/0)
yaw - compass course
bat - battery voltage
chg - charger voltage sensor
--- commands ---
'h': drive home
'p': track perimeter
'l': simulate left bumper
'r': simulate right bumper
's': simulate lawn sensor
'm': toggle mower motor
'c': simulate charging
'+': rotate 90 degrees
'-': rotate 90 degrees
'3': activate model RC
'0': OFF
'1': Automode motorMowEnable
  1. Diagnostic
