Error codes
If your robot beeps periodically, it is in ERROR state. Either run the serial console or 'pfodApp->Error Counters' to find out the detailed error. The possible solutions for each error are given below.
ERR_MOTOR_LEFT Left gear motor error * Check gear motor driver module and left gear motor * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_RIGHT Right gear motor error * Check gear motor driver module and right gear motor * MC33926: ensure SLEW jumper is not set * Tracking: reduce Motor-Max-PWM and Tracking-P to reduce EMF ERR_MOTOR_MOW Mower motor error * Check mower motor driver module and mower motor * MC33926: ensure SLEW jumper is not set * Reduce Motor-Max-Power, so over-current is detected earlier ERR_MOW_SENSE Mower motor over-current * Check mower motor driver module and mower motor * Increase Motor-Max-Power, so over-current is detected later ERR_IMU_COMM IMU communication error * Check IMU module connections ERR_IMU_CALIB IMU calibration error * Start IMU calibration (either via Console or pfodApp->Settings->IMU) ERR_IMU_TILT IMU tilt error * Check IMU module and robot orientation ERR_RTC_COMM RTC communication error * Check RTC module connections, RTC battery etc. ERR_RTC_DATA RTC corrupt data error * Set and save RTC date and time ERR_PERIMETER_TIMEOUT Perimeter signal timeout * Check perimeter sender, wire etc. * Reduce Perimeter-smag, so timeout is higher * Increase Perimeter-timeout-seconds, so timeout is higher ERR_TRACKING Perimeter tracking error * Check perimeter sender, wire etc. * Increase Perimeter-tracking-timeout, so timeout is higher ERR_ODOMETRY_LEFT Left motor odometry error * Check left odometry cable ERR_ODOMETRY_RIGHT Right motor odometry error * Check right odometry cable ERR_BATTERY Battery error * Check battery connections ERR_CHARGER Charger error * Check charger connections ERR_GPS_COMM GPS communication error * Check GPS cables ERR_GPS_DATA GPS data error * Check GPS antenna and cable ERR_ADC_CALIB ADC calibration error * Start ADC calibration (either via Console or pfodApp->ADC calibration) ERR_EEPROM_DATA EEPROM data error * Save user settings (either via Console or pfodApp->Settings-Save)
Motors working correctly
Some sensor not triggering?
Bluetooth not connecting?
Console output
--- commands ---
