Perimeter wire
Version vom 12. September 2014, 19:53 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Perimeter v2 (SVN version))
Perimeter v1 (v0.9.3)
So, here's the sender:
Functional test
Receiver
Principle:
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
While crossing the perimeter loop, something interesting happens: signal changes polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire will be detected. The robot knows its current perimeter state all the time (inside/ouside). As with perimeter v1, we will again use a motor driver to generate the signal and an operation amplifier to amplify the received signal.
Principle:
  1. Amplify perimeter coil signal using OPAMP
  2. ADC sampling using Arduino
  3. Signal filterung and detection using a digital filter (Matched filter algorithmn).
  4. Evaluation of filter output
Simulation
Signal shape, filter and simulation Matched filter simulation
Receiver
