GPS ru
Version vom 22. August 2015, 17:27 Uhr von Unlogic (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „=Описание= <gallery> File: ublox_neo_6m.jpg File: GY-NEO6MV2_schematics.jpg </gallery> With the help of a GPS receiver (e.g. GY-NEO6MV2, ublox 6m), t…“)
Описание
Currently, GPS is used
GPS TX (3.3V compatible) -- Arduino RX GPS RX (3.3V compatible) -- Arduino TX GPS VCC -- Arduino VCC 5V GPS GND -- Arduino GND
Visualization of GPS data
GPS error
Typical GPS error is 2-5 meters (at a sample rate of 1 Hz). As this is not sufficient as a replacement for a perimeter wire, GPS can only be seen as an extension or for global navigation (navigation from one lawn to another lawn) or to improve the result of a sensor fusion.
