Ardumower chassis ru
Version vom 22. August 2015, 20:14 Uhr von Unlogic (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „ This page describes the assembly of the Ardumower chassis that you can purchase via the [https://www.marotronics.de/index.php?k=32 shop] File: shopping.png|…“)
- Max. slope: 14 degree
- Mowing slice: 190mm diameter, 3 blades
- Wheels: 250mm diameter
- Gear motors: 2 x DC 24V planetary drive, 33 rpm, with encoders (required)
- Battery: Lithium-Ion 29.4V
- Chassis assembling
- Chassis assemling (slow)
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
What you need
- Screw driver
- Imbus screw driver
Case assembly
... Your help is needed to fill in photos here ...
