Motor driver ru
Version vom 22. August 2015, 20:17 Uhr von Unlogic (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „= Описание = Ardumower's design uses two different types of motors (all motors can be purchased via the [https://www.marotronics.de/index.php?k=7 shop]…“)
Описание
Ardumower's design uses two different types of motors (all motors can be purchased via the shop Shopping.png):
  • Two motors (with integrated gearing) for driving (wheel motors), and encoder (for distance, direction and speed control)
Voltages
  • The motor driver must be suitable for higher current (more expensive)
  • The PCB traces need to be more thick (more expensive)
  • The rechargable battery need to support higher current (more expensive)
Wheel motors
  • steer the robot left/right
  • Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
  • 24V (load current ~1A)
Motor driver
 Arduino Digital Pin  —>  MOTOR-Direction Pin (DIR)
 Arduino PWM Pin      —>  MOTOR-Speed Pin (PWM)
 Arduino Analog Pin   <—  MOTOR-Current Sensor Pin
PWM frequency
Popular modules
MC33926 (recommended)
M1_FB     --- pinMotorLeftSense A1
M1_SF     --- pinMotorLeftFault 25
M1_IN1    --- pinMotorLeftPWM 5
M1_IN2    --- pinMotorLeftDir 31
M2_FB     --- pinMotorRightSense A0
M2_SF     --- pinMotorRightFault 27
M2_IN1    --- pinMotorRightPWM  3
M2_IN2    --- pinMotorRightDir 33
VDD       --- Arduino 5V
L6201P
Features: 48V, 4A
B+     power supply output voltage equal to the power connector
GND    GND
EN     driver enable
RPWM   forward PWM signal, active HIGH
LPWM   reverse PWM signal, active HIGH
CT     current signal output
VT     voltage signal output
Forward   EN=1, RPWM=PWM, LPWM=0
Reverse   EN=1, RPWM=0,   LPWM=PWM  (also possible?   EN=1, RPWM=255-PWM, LPWM=1  => needs to be verified!)
Brake     EN=1, RPWM=0,   LPWM=0
Not brake EN=0, RPWM=x,   LPWM=x
Note: 1=High level (3.3-5v), 0=Low level (0V or GND)
L9958
L9958 GND---GND
L9958 VCC---Arduino 5V
L9958 EN---Arduino 5V
L9958 DI---GND
L9958 DIR---Arduino MOTOR_DIR
L9958 PWM---Arduino MOTOR_PWM
L9958 MOTOR(+)---motor(+)
L9958 MOTOR(-)---motor(-)
L9958 POWER(+)---battery(+)
L9958 POWER(-)---battery(-)
L298N
Connect in parallel:
IN1 with IN4
IN2 with IN3
OUT1 with OUT4
OUT2 with OUT3
Mower motor and driver
Choosing a driver
  • price
Starting current
Starting current:
  • Gear motor: 15A (starting current peak)
  • Mowing motor: 20A (starting current peak)
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
