Hall sensor ru
Version vom 23. August 2015, 14:53 Uhr von Unlogic (Diskussion | Beiträge) (→‎Подключение)
Датчик Холла
caption
Сама идея: The blade has the best performance with a certain minimum speed (e.g. 3300 rounds per minute/rpm). If the blade is rotating at maximum voltage (independant if there's high or low grass), it's not saving battery power, and the robot is loud too.
Now, if you measure the rotations of the blades, you can control the voltage: on high grass (rotation decreases) voltage is increased, and on low grass (rotation increases) voltage is decreased.
So, you'll need a rotation sensor for the blades, e.g. using a Hall sensor (A1302 KUA-T) and a small magnet (Neodym magnet) added on the engine shaft.
Click here [1] for demo video
Подключение
Датчик Холла A1302 +5V    ----  +5V
Датчик Холла A1302 GND    ----  GND
Датчик Холла A1302 Signal ----  Arduino вывод 18
