Motor driver
Version vom 11. September 2014, 11:28 Uhr von Alexanderg (Diskussion | Beiträge) (Die Seite wurde neu angelegt: „__TOC__ == Abstract == To control a motor, it requires a 'motor driver' - a circuit that allows current to flow either one direction or the opposite direction…“)
Popular modules
  • MC33926, up to 3A with integrated current sensor and thermal shut-down protection (for all kind of robot mowers)
  • STL298N (Arduino L298N motor driver), up to 4A (for Tianchen TC-G158, Ambrogio L50, etc.)
  • STL6203/STL6201PS, up to 4A
  • STL9958 (Arduino 240W H-bridge Motor Driver Board - SX8847), up to 8A (for Rotenbach SPM08-320 etc.)
Wheel motors (H-Bridge)
Arduino Digital Pin —> MOTOR-DIR Pin
Arduino PWM Pin —> MOTOR-PWM Pin
Arduino Analog Pin <— MOTOR-Current Sensor Pin
MC33926 motor driver
L298N motor driver
L9958 motor driver
Mower motor (MOSFET)
Choosing a driver
  • price
Short-circuit current
Warning
  • always remove blades
Example measurement:
  • Rotenbach SPM08-320
    • Wheel motor: 8A
    • Mowing motor:
  • Ambrogio L50
    • Wheel motor: 4,5A
    • Mowing motor: 22A
  • Tianchen TC-G158
    • Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
