Arduino Crash Kurs
1. Dein erstes Programm
void setup()
void loop()
Aufgabe:
1. Lösung
void setup()
void loop()
Aufgabe:
2. Lösung
void setup()
void loop()
3. Ein Taster
Aufgabe: 1. Schliesse den Taster an Pin 5 an und definiere den Pin:
int pinSwitch = 5; // Pin für Taster definieren
Serial.println( zustand );
3. Lösung
int pinLED = 13; // Pin für LED
void setup()
pinMode(pinLED, OUTPUT); // LED soll als Ausgang konfiguriert werden
Serial.begin(115200); // serielle Konsole mit 115200 Baud konfigurieren
void loop()
Serial.print("Taster ist ");
delay(1000);
void setup(){
Serial.begin(19200); // set the baud rate to use
void loop(){
delay(1000);
For-loops and blocks
Hello 0 Hello 1 Hello 2 Hello 3 ... then the main loop restarts...
void loop(){
Serial.print("Hello ");
Serial.println(counter);
delay(1000);
Try it out!
Digital input
int pinLED = 13; // we use the Arduino onboard LED
void setup(){
void loop(){
Serial.println( value );
delay(1000);
Try it out!
If-clauses
void loop(){
if (value == HIGH){
else {
delay(1000);
if (numberX > 5)... // variable 'numberX' must be larger than 5 if (numberX > numberY) ... // variable 'numberX' must be larger than variable 'numberY' if (numberX == numberY) ... // 'numberX ' must be equal 'numberY' if (numberX < numberY) ... // 'numberX' must be smaller than 'numberY'
if ( (number > 5) && (number < 10) )... // logical AND: both conditions must be TRUE if ( (number < 5) || (number > 10) )... // logical OR: only one condition must be TRUE
What you have learned
- Variables can contain numbers (integer, float) or text (characters) and are placeholders for them.
- Functions can containe blocks of code and are placeholders for the blocks.
