Arduino Crash Kurs
Version vom 1. April 2016, 10:25 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Serial console output and text)
1. Dein erstes Programm
 void setup()
 void loop()
Aufgabe:
  delay(1000);               // Warte 1000 Millisekunden (= 1 Sekunde)
  digitalWrite(13, LOW);     // Pin 13 soll auf LOW ( 0 Volt/Masse ) gesetzt werden
1. Lösung
 void setup()
 void loop()
Aufgabe:
2. Lösung
 void setup()
 void loop()
3. Ein Taster
Aufgabe: 1. Schliesse den Taster an Pin 5 an und definiere den Pin:
int pinSwitch = 5;  // Pin für Taster definieren
  Serial.println( zustand );
  delay(1000);
3. Lösung
 void setup()
 void loop()
   Serial.print("Taster ist ");
   delay(1000);
For-loops and blocks
Hello 0
Hello 1
Hello 2
Hello 3
... then the main loop restarts...
 void loop(){
     Serial.print("Hello ");
     Serial.println(counter);
   delay(1000);
Try it out!
Digital input
 int pinLED = 13;  // we use the Arduino onboard LED
 void setup(){
   Serial.begin(19200);
 void loop(){
   Serial.println( value );
   delay(1000);
Try it out!
If-clauses
 void loop(){
   if (value == HIGH){
   else  {
   delay(1000);
if (numberX > 5)... // variable 'numberX' must be larger than 5
if (numberX > numberY) ... // variable 'numberX' must be larger than variable 'numberY'
if (numberX == numberY) ... // 'numberX ' must be equal 'numberY'
if (numberX < numberY) ... // 'numberX' must be smaller than 'numberY'
if ( (number > 5) && (number < 10) )... // logical AND: both conditions must be TRUE
if ( (number < 5) || (number > 10) )... // logical OR: only one condition must be TRUE
What you have learned
  • Variables can contain numbers (integer, float) or text (characters) and are placeholders for them.
  • Functions can containe blocks of code and are placeholders for the blocks.
