Motor driver
Version vom 29. Mai 2016, 23:10 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver (dual MC33926))
  • Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
To control the motors, it requires motor drivers. Ardumower uses two dual MC33926 motor drivers, so two channels for left and right motor and two dual channels (connected in parallel) for the mowing motor.
Voltages
Although there exist 12V motors and 24V motors, as in all modern systems, the Ardumower uses 24V motors.
Wheel motors
  • steer the robot left/right
  • Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
  • 24V (load current ~1A)
Features: up to 3A with integrated current sensor and thermal shut-down protection
Warning.pngProtector board is adviced to be used between controller and motor
Motor wiring (left motor):
black  ==== MC33926 M1OUT1
red    ==== MC33926 M1OUT2
brown  ---- PCB VCC
green  ---- PCB GND
blue   ---- PCB OdometryLeft (3)
purple ---- PCB OdometryLeft (4)
For right motor, use MC33926 M2OUT(1,2) and PCB OdometryRight.
odometry1 --- 4.7k --- 5v
odometry2 --- 4.7k --- 5v
MC33926 jumpers:
Mower motor
Motor controller (PID)
Programming
Motor variables
   // --------- wheel motor state ----------------------------
   // wheel motor speed ( <0 backward, >0 forward); range -motorSpeedMaxRpm..motorSpeedMaxRpm
   //                                   [Default value]
   float motorAccel  ;          // motor wheel acceleration - only functional when odometry is not in use
                                // (warning: do not set too high) [1000]
   int motorSpeedMaxRpm   ;     // motor wheel max RPM  [25]
   int motorSpeedMaxPwm  ;      // motor wheel max Pwm  (8-bit PWM=255, 10-bit PWM=1023) [255]
   float motorPowerMax   ;      // motor wheel max power (Watt)
   PID motorLeftPID;            // motor left wheel PID controller [Kp=1.5 , Kd=0.29, Ki=0.25]
   PID motorRightPID;           // motor right wheel PID controller
   float motorSenseRightScale ; // motor right sense scale (mA=(ADC-zero)/scale)
   float motorSenseLeftScale ;  // motor left sense scale  (mA=(ADC-zero)/scale)
   int motorRollTimeMax ;       // max. roll time (ms)
   int motorRollTimeMin  ;      // min. roll time (ms)
   int motorReverseTime ;       // max. reverse time (ms)
   long motorForwTimeMax;       // max. forward time (ms) / timeout
   float motorBiDirSpeedRatio1 ;// bidir mow pattern speed ratio 1
   float motorBiDirSpeedRatio2 ;// bidir mow pattern speed ratio 2
   bool motorRightSwapDir     ; // inverse right motor direction?
   bool motorLeftSwapDir      ; // inverse left motor direction?
   int motorLeftSpeedRpmSet ;   // set speed
   int motorRightSpeedRpmSet ;
   float motorLeftPWMCurr ;     // current speed
   float motorRightPWMCurr ;
   int motorRightSenseADC ;
   int motorLeftSenseADC ;
   float motorLeftSenseCurrent ;
   float motorRightSenseCurrent ;
   float motorLeftSense ;       // motor power (range 0..MAX_MOTOR_POWER)
   float motorRightSense ;
   int motorPowerIgnoreTime;
   int motorZeroSettleTime;     // how long (ms) to wait for motor to settle at zero speed
   int motorLeftSenseCounter ;  // motor current counter
   int motorRightSenseCounter ;
   unsigned long nextTimeMotorSense ;
   unsigned long lastSetMotorSpeedTime;
   unsigned long motorLeftZeroTimeout;
   unsigned long motorRightZeroTimeout;
   boolean rotateLeft;
   unsigned long nextTimeRotationChange;
Motor Methods
First the basic function that control the pwm to each motors:
 void setMotorPWM(int pwmLeft, int pwmRight, boolean useAccel);
A general methods to test motors
 void testMotors();
Then, there are several MotorControl methods according to mower state :
if current state is 'STATE_PERI_TRACK' then
 void motorControlPerimeter();
 void motorControlImuRoll();
 void motorControlImuDir();
for all other case :
 void motorControl();
 // This method calculate pwm to set in order to respect rpm setpoint according current rpm and Kp, Ki, Kd parameter
