Charging
Version vom 31. Mai 2016, 10:34 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Standby-off / Under-voltage protection)
Basic principle
Charger
Total power balance
Battery
schematics
Robot charging
Charging station
charging station circuit:
                    GND         (-)----- Charging station charger pin(-)
                    Charger 24V (+)----- Perimeter sender PCB power input
Charging station ideas
  2. Drive in and out
  3. Tracking and docking
  4. Final version
